Another newb question
I have a 2002 LS1 and want to know if fuel rails (not blue or red) are available that eliminates the cross over. Any just polished? And can the inlet be at the rear?
You can make any after market rail kit eliminate the crossover...Alll you have to do it put a y-fitting before the rails and then have the two lines coming from the rails go into another y-fitting after the rails.
That of course assumes one knows what a y-fitting is Let's see if I understand. 1 line comes from the tank and gets split before the fuel rail and one line goes into each rail? The other end of the rails are connected by another line?
