Racetronix Pump Install Help
Old 02-26-2007, 09:28 AM
SebastianLopezJr's Avatar
Default Racetronix Pump Install Help
I ordered a Racetronix kit for a 2002 LS1 Camaro plastic tank w/wiring harness kit though a GP last summer. Never got around to putting it on till now since my stock pump went out. Got the car apart, started putting the thing together and then notice on the box the pump came in its marked FLT1-FPA but the harness is marked 99+ LS1. Is this supposed to be like this? My kit has no directions so if anyone has any to share, please post or email them to SLJ@LopezRacing.com . Imp not sure what to do or if can make this work. The little filter that came with it does not fit on the bottom of the pump but then again I am not sure if that’s where it goes.
Any help is greatly appreciated since I took the day off to fix this & have no car right now, plus I don’t want to spend $399 for a stock replacement pump when I have already spend $250 or whatever it was before. Thanks.
Old 02-26-2007, 07:18 PM
LS1TECH Sponsor
Lonnies Performance's Avatar
The pump should be a F99-FPA... you have an LT1 pump.
Old 02-26-2007, 07:27 PM
myfast70's Avatar
Iwould contact whoever you purchased it from and see if they can swap it out. Explain your story and they may work with you.
