Racetronics Plug and Play=NO GO!!!!
Hey guys i ordered my racetronics plug and play system a couple months ago, and am just now getting around to getting it together. Well i have everything wired right, and i have the right pump and everything, but it just doesnt kick on. It wont pump any fuel, almost as if the pump was shot. I bought this system used from a member on the board so i guess it is a possibilty that the pump is no good, but what do you guys think?
and i checked the relay, it has power at the main, and when i crank it for a second, it gets power at the switch + of the relay then goes off...any takers? plugged the stock pump back in, turned the key and it worked perfectly...
