No fuel pressure after pump change?
Did you do multiple primes like was suggested you in your other thread? Did you check for presure at the schrader on the rail?
Check the relay and your wiring.
I am as curious about why you need two threads for the same question as you are about why your pump does not work.
when you say multiple primes you mean turn the key one and off and one and off but not cranking and someitme inbetween ill hit the gass pettle after that i go back up for the shrader valve and i open it and nothing leaks sprays or anything with it the pump works i know that since when you turn the key you hear it working.....
