Is this enough for my 408?
I am interested in buying the following:
Delphi 42lb injectors & 255 Walbro in tank - will these be enough for my 408? what about with a 200 shot of nitrous on top of it?
Thanks in advanced!
Thanks in advanced!
They may be a little thin with the 200 shot not totally sure. But my experience was, I bought 42's for my procharged 347. I quickly outgrew them when I installed the 408, I am FI and that does make a difference. But my advice is, if you are having to buy new injectors anyway, unless you are getting a smoking deal on the 42's, personally I would go straight to the 60's.....JMO
If it is a wet kit the injectors are plenty. As for the pump it is fine for the motor but you will need alot more fuel for the 200 shot. You have a couple different options to handle that much power like our Stage3 street kit or a stand alone nitrous fuel system.
http://www.nastyperformance.com/FuelSystems.html
Nate
Nate
