408 Guys : What injectors / pumps are you running?
I am on a stock fuel injector and fuel pump & want to know what I should go with. I am thinking between 470-480rwhp through an auto is what i will be at, and maybe a 200 shot of spray after. What else will I need?
I had 42lbs injectors with a walbro intank pump. I was fine on the motor. For anyone else that chime in will a twin intank pump with 42lbs injectors support what he is trying to spray and his motor? Just courious.
Race your car!
I am running a 402, and have a racetronix setup with the hotwire kit and 42 lb ford injectors. I'm planning on running about a 100 to 175 thru a plate kit, and will add a boostapump when the kit gets hooked up.
IMO, any more then a 175 shot and you should be doing a DP setup, and at that point a standalone for the nitrous is a real good idea, taking alot of the load off the fuel system, making what I'm running, or a walboro 255/42lb injector setup adequate.
