Do I need new injectors & a stand alone??
I am running with stock injectors right now. The car is an 02 SS with full bolt-ons, exhaust, and a mild cam. It made 400rwhp and 380rwtq before I put the 12 bolt in. Its getting a NX wet kit put in in a month or so with a stand alone fuel system for the juice. Do I need bigger injectors, even though I will be using a stand alone fuel system? Are the stock injectors enough for what my motor is making? If not, how big should I go?
Your stock injectors will be fine in that application, the NX system is adding fuel for the nitrous (if it's a wet kit which I'm assuming since you said you're getting a stand alone), so the car is really isn't doing anything different, you're just adding fuel and nitrous (and hopefully backing some timing out) independantly.
