Got new Racetronix installed and works. Have a PNP question...
Like the title says, the pump is in and works on the stock harness. When we install the PNP harness it doesn't get power to the pump. The relay clicks at the rear of the car and all, but no power to the pump. The fuel gauge reads E, as in it's not getting any signal from the harness. I'm thinking everything is wired up right...how hard is it...it's all just pluggin in things. Everything gets power but the pump.
Any ideas?
Any ideas?
Everything checks out. The ground at the back of the car is good. I have 12 volts going into the relay. The relay clicks when the switch is turned. Just no power to the pump....it's odd that it will work with the stock harness just fine, but not with the new one. I drove it for 40 miles or so with the stock harness and new pump.
LS1TECH Sponsor
__________________
Manufacturer / Distributor of Automotive Fuel Systems, Components & Electronics
Please support a Racetronix dealer near you for personalized service.
>WEB SITE<
>WEB SITE<
