Fuel line size/upgrade question
If the..
Originally Posted by Phil99vette
My fuel cell has 2 -8 outputs but I really need 1 -12. Should I just take the two -8 into a Y block to one -12 or should I remove one of the -8s and install a -12? My other fuel cell has 2 -8s but I only need a -6.
Phil
Phil
If the fitting is designed as a "pickup" fitting, it'll have the inlet side made w/ a nice radius, for better flow. If not, I put it in a lathe, and add the radius.
I use a nylon seal/washer on both sides of the fitting...
On the other cell, I'd remove 1 fitting, and replace it with a -6 bulkhead, made from an "adapter" bulkhead.[-8 to -6]. This may require some lathe work, but is easily done, in just a few minutes.
Now, if the cells are metal.. Another deal, all together
