Fuel systems questions
I just bought a Fast intake and fuel rails and have some install questions. I know I need a Fast fuel line kit (or make one myself) but I am unsure what else I need to complete the installation. Do I need any special adapters for the stock fuel lines? I know I need a regulator can someone make a suggestion. What about the return line? Can someone post pics of a Fast setup installed so I know what my install should be like. I'm unsure of where I should put the new regulator. Thanks for the help!
We have an istall kit for the FAST rails and you do not need a regulator as it is in the fuel tank with the pump. Uless you are going to hp over the 600rwhp make you wil not need to add a reg. and return line. If so I have a kit for that as well.
http://www.nastyperformance.com/FuelSystems.html
Nate
Nate
