KB BAP install with Lonnies dual pump harness
Old 06-04-2007, 08:11 AM
eb02z06's Avatar
Default KB BAP install with Lonnies dual pump harness
How do you install the KB BAP with Lonnies dual pump harness? Before with the single pump i just tapped into the grey wire which was the factory trigger for the pump. Now with the Lonnies harness the there are to main wires that connect to the positive side of the battery that feed power to the pumps.
thanks
Old 06-05-2007, 12:12 PM
Nasty N8's Avatar
Should not be needed unless you are pushing the limits of the pumps with a complete fuel system.
Nate
