Which Fuel Pump? (Not what you think)
I have a '94 v6 that was swapped to an LS1. It's got a '99 PCM in it and an LT1 fuel pump. I see that the Walbro 255 is the same part no for LT1 or LS1 cars but I would like to use the Ractronix plug and play kit so that I can get the upgraded wiring. Anyone have any idea which on to use between the two? Will the LS1 pump for the 98's drop into my tank and plug into my harness?
LS1TECH Sponsor
The Walbro pump is not the same for an LS1 & LT1 unless you are looking at universal pumps. The correct ones distrbuted by Racetronix are different.
Since you have a 94 car, you need a LT1 pump & harness assembly.
If interested, I can get you the correct parts for your application.
