Minor repair advice needed
Old 07-03-2007, 07:57 AM
1FSTLS1's Avatar
Default Minor repair advice needed
Ok so my QTP cutouts hit my fuel line and put a dent in it. Not cool. My idea for an easy fix is to cut the fuel line put a peice of rubber hose and give it a sligt bend and put two small hose clamps on both sides.
Would this be a good fix? Any other ideas? And may as well change the fuel filter while Im down there.
Old 07-03-2007, 09:25 AM
Nasty N8's Avatar
No it will not hold the pressures with just a clamp. Need to be some sort of fitting.
Nate
Old 07-03-2007, 09:31 AM
1FSTLS1's Avatar
Wonder if I could get something from AutoZone or Nappa that would work. From what I remember the fuel lines are tight to the frame not much room to work.
