the most common fuel pump problems are???
Fuel pump before header install= good
Fuel pump after header install= not good
WTF??? Is there something common to the 93-97 Camaro/Firebird I could check? My car wont even start now. I turn the key and theres no sound of the fuel pump. Not even on the first try after sitting for a week or so.
What is common however - is for the pump to fail in minutes if you run it low forcing the pump to cavitate and burn up (the pump stays cool because it is submersed in fuel). One city block on mty will burn the pump up.
The Racetronix Kit is hands down the best kit when upgrading and will support 500 and a little over - rwhp.
