Billet fuel rail question
I am looking for pictures of your billet fuel rails and a close up of the fittings to connect the hard line to the stainless steel braided line. I have the Speed Inc kit and there were no instructions with the fuel rail kit.
This is what I recieved. Am I not seeing something right on how it connects. I have the rails and fittings to connect the rails together right and the brackets to connect the rails to the manifold.
The straight blue connector in the middle of your first picture is your hard line quick connect. When you remove your factory rubber hose from the fuel hard line on the wheel well, you push the quick connect over the hard line.
There should be another straight hose end in the kit as well. The fuel line that you make to feed the rails has the straight end to connect to the hard line and then the 90 degree to feed the rails. You just connect the straight hose end to the quick connect.
