Flow rate for 25317628 injectors
Old 07-04-2008, 11:12 PM
Project_SS's Avatar
Default Flow rate for 25317628 injectors
I've been told that they are 42lb injector. However from the information that I've found these 25317628 injector are rated 22.1 @ 43.5 psi. Can someone verify this or correct me if I'm wrong.
Looking for some injectors to use with a ls2, l92 heads and l76 intake. Setup will be in a 99-00 Camaro with ls1 pcm
Old 07-05-2008, 12:10 AM
gold98Z28's Avatar
i believe that part number 25176061 is the one you might be looking for.
That is the 8.1 liter MARINE injector. Same injector that comes with the Radix kits. It is a 42 pound injector at our 58 psi pressure.
Quick Reply: Flow rate for 25317628 injectors
