Dana 60 and tru track..how much can it take really?
Old 11-16-2008, 12:21 PM
MY99TAWS6's Avatar
Default Dana 60 and tru track..how much can it take really?
My car is pretty much 100% street car. Its going to roll on nittos almost all the time but might track it once or twice just to pretty much hang the time slip on the wall. I would run likley et street radials 16 inch for the track runs.
I will be auto 4l80e with like a 3400 stall.
I am not sure how much power would try to run at the track. Would like to hit a high 9 at say high 130s and think can get that at around 12psi not counting spray. Was planning on small shots 75 to 100 max but not necessarily needed dont think to hit th high 9s.
Car won't be fully track legal for 9s well not even close..but will go to this slacker track to run most likely.
I dont really want a spool or locker for my planned dana 60. I know the axles and gears are very strong on the dana 60 so only the tru trac might break.
How much are you guys putting thru it especially on an auto with the tru trac not locker or spool. Would I maybe be ok for some say 700rwhp launches? Or is that tru trac going to break first pass.
or should I try to stay at say 600 or so rwhp. Not sure how much power I will need to hit high 9s I realized it depends on 60fts and not sure what 60fts to expect .Would think with 3400 stall and et street radials could hit some 1.6s if can build some boost with my two step and antilag. Car is not drag strip opitimized ,its going to be like 4200 race weight.
Willl the tru trac be ok if dial it up to say 1000rwhp and just street it .No really hard high rpm launches on drag tires.Nittos of course can't hook that kind of power. I woudl think six speeds would also break the tru trak easier do to the way they shock the rear end?
Old 11-16-2008, 05:19 PM
LS1Tech Sponsor
Scott@DrivelineSolutions's Avatar
Eaton claims the Truetrac in a Dana 60 is good for 1000hp and that would be your weakest link IMO.
Old 11-16-2008, 06:35 PM
Black02SLPSS's Avatar
1000hp?? thats all?? lol
Old 11-16-2008, 06:40 PM
MY99TAWS6's Avatar
I assume that was not 1000 rwhp. Also I still think you could go higher hp as long as you dont really hook up and shock hell out of it. Guys manage to run very fast with the stock 10 bolts on autos .
Old 11-16-2008, 06:57 PM
MY99TAWS6's Avatar
So guys how much power have you put thru your dana 60 tru trac?
Lets have a few examples.
Old 11-16-2008, 07:04 PM
macleod's Avatar
646rwhp/598rwtq. Other than the whine at 40-50mph which seems to be common I have had no other problems.
Old 11-16-2008, 07:08 PM
MY99TAWS6's Avatar
Thanks Mcleod thats what want to see. I am hoping my dana is pretty quiet if not mabye swap in some other make of gears hearing Yukons are very quiet. I won't put up with bad noise in this car. Went thru it in the past with the 10 bolt and went back to 3.42s.
Old 11-16-2008, 07:23 PM
bad6as's Avatar
my truetrack is broke and it was from cam only launches
Old 11-16-2008, 07:38 PM
MY99TAWS6's Avatar
Is ths a dana 6o tru trac..so this is in an m6 car? What 60fts..? Cam only cars shouldn't be anywhere near enough power to break it. Wheel hop?
Faulty part?
Old 11-16-2008, 07:40 PM
bad6as's Avatar
mines in a 9" m6 car. 1.69 60fts 3675lbs. its still driveable, but pops and hops on slow sharp turns, havent got a chance to take it apart yet, but other have have the same issue i had
Old 11-17-2008, 12:18 PM
AChotrod's Avatar
but in a 9" or S60?
I just bought a S60 and on the receipt it says Dana S60, 35spline, true trac 4.10,chrome cover with DS an yoke rate 800hp. Not sure if thats the DS or the entire set up? Either way I dont have 800hp LOL!
Old 11-17-2008, 12:26 PM
MY99TAWS6's Avatar
s60 is what I am getting. And 800 isn't enough for me. I will have 800rwhp minimum with auto trans 850 rwhp minimum with m6 but could wind up with more like 1100 rwhp . Course no intention of drag stripping the car at 1100 rwhp that would be mostly for off track use..LOL And would think only way to hurt the true track is hard launches at the track and auto should help after all some guys run like 500 hp or more thru their 10bolts with the auto absorbing the shock of launch.
I guess might just have to buy the normal s60 and see how it does.If keep blowing up tru tracks then maybe consider locker or spool.
Old 11-17-2008, 04:21 PM
barnat's Avatar
Im shopping for a rear as we speak !Whats the diff between the tru track and a locker on the street?
Old 11-17-2008, 11:09 PM
MY99TAWS6's Avatar
The old lockers were not good on the street not sure about the new ones.
Old 11-18-2008, 12:32 AM
pushinfreight's Avatar
Most damage to the rear is from wheel hop. The dana 60 will hold plenty of power. If it is good enough for CORE off road trucks then it will work for us. Just make sure that you get relocation brackets put on when you get it and some adjustible lower controll arms to ensure that the rear is centered and that will eliminate most of your problems. For more help get a drag rear sway bar like BMR sells. If you are really going to push 1000rw **** is going to break. Get use to it.
Old 11-18-2008, 10:17 AM
BMR Tech's Avatar
Would have to agree...
Old 11-18-2008, 08:16 PM
getusum's Avatar
Same issues......No way 1000 rwhp.....I've heard different from other guys, but do a search and alot of us m6 guys have issues from dumping the clutch over 5500 rpms...
Old 11-18-2008, 08:17 PM
getusum's Avatar
Originally Posted by AChotrod
but in a 9" or S60?
Check again,,,,Tru Tracs only up to 31 spline......No way on 35 spline....Might go to 33 spline, but I'm pretty sure only 31 spline...
Old 11-18-2008, 08:41 PM
MY99TAWS6's Avatar
Ok time to rephrase a bit. I only want to hear from Dana 60 guys with that tru track or whatever they call it ..And auto guys.
I am swapping in a 4l80e in spring anyway and car won't be tracked until it has the dana and the 4l80e.So autos usually let you run sometimes even stock 10 bolt to big power levels. I also can turn my power down some to around 650 rwhp lowest maybe as figure that should get me a 10 or maybe high 9 at the track? On the street wouldnt think could break the tru trac or whatever its called as woudln't have the traction and be launching like at the track.
So no disrepect to you 9 inch guys but going with dana 60 with basic diff. not spool and not locker. If break the diff it comes with then have to think about what to do.
Old 11-19-2008, 09:20 AM
BMR Tech's Avatar
The Tru Trac in the S60 is 35 spline .........
Quick Reply: Dana 60 and tru track..how much can it take really?
