rear end swap
the brakes are different but they should work fine in your older car(better actually). The only real problem i see is if your new rearend is a 4channel(sensors out on the ends with the brakes). I think lt1 cars all had 3channels(1 sensor on top of the center section). You don't have to have a 3 channel for it work but you will lose you ABS and you will get a light on the dash for it.
