Magnet in the rearend....???
Old 01-06-2009, 03:51 PM
99ssleeper's Avatar
Default Magnet in the rearend....???
Where can I find the triangular type magnet that slides into the bottom of a 10 bolt housing?
My previous 99 SS with the Auburn diff had one since it came with the aluminum cover. I'm adding a TA cover to my current car but would like to have a magnet in there too.
Any info?
Old 01-06-2009, 04:43 PM
01ssreda4's Avatar
could you use a generic magnet??
Old 01-07-2009, 06:20 AM
toadzq8's Avatar
The TA cover uses a 1/4 NPT plug for the drain, I went to a lawnmower shop and got a 1/4 NPT drain plug with a magnet in it and stuck it in, works great. You can clean it and see how much metal your getting, with out pulling the cover. cost about me $4.00
Old 01-07-2009, 07:31 AM
99ssleeper's Avatar
Thanks for the info toad. I'll check that out, I didnt look at the cover close enough to see what plug they used.
01ss, I thought of going to the hobby shop to see if there was a similar sized magnet that would fit in there. Thought maybe I would luck out and someone had one stuck on their toolbox or something!
Thanks guys.
