3 channel strange 12 bolt in a 4 channel car?
Old 01-18-2009, 12:22 PM
dudeman's Avatar
Default 3 channel strange 12 bolt in a 4 channel car?
how would you do this? can you just press on the rings to the axle? any help would be appreciated!
Old 01-18-2009, 06:20 PM
dschmittie1's Avatar
I think But I am not 100% sure but I think the axles may be different.
Old 01-18-2009, 06:38 PM
SS1875's Avatar
16. Will a 3 channel rear end work in my 4 channel car?
Yes, you can make it work, if you put the axles from your four channel car into the 3 channel rear end and install the sensors into the backing plate. To put a 4 series into a 3 series would be more difficult, because it would require you to drill in the top of the rear housing for the sensor, and add a reluctor ring to the carrier as well.
