Axle Bearing Removal Help!
Old 02-10-2009, 11:31 AM
ShevrolayZ28's Avatar
Default Axle Bearing Removal Help!
Damn! I looked at it and said, let a shop do it. These guys had my axles since Friday and couldn't get the bearings off!
These are Moser axles for a 9". Anybody got any tips?
Thanks!
Old 02-11-2009, 10:28 PM
SS SLP2's Avatar
best tip=different shop, any good shop should remove then in 10-30 min tops, if press will not remove they should apply heat or grind them off
just my .02' Johnny
Old 02-12-2009, 12:28 PM
just my .02' Johnny
You were right. I went to another shop and they got them off pronto. Pretty much had to cut them off because of the backing plates getting in the way.
I don't think you wanna heat them up as it may mess with the hardened axle.
