12 bolt question
12 bolt question
If I buy a 12 bolt that has lower control arm relocation brackets will i have to buy aftermarket control arms....
What all will I need to put this in a stock suspension car that has lowering springs...will i need aftermarket torque arm, panhard bar, sway bar
My suggestion would be to get some adjustable LCA's/TA/ PHB, Stock sway bar is fine.
You may have to buy some 3" u-bolts to relocate the stock sway bar (bigger axle tubes)or buy the relocation kit from Spohn.
Possibly need some zip ties for the brake lines and e-brake cables(depending on 3ch or 4 ch)...at least for a Moser.
