aftermarket torqe arm same for 10 bolt as 12?
1 Post
i have a BMR adjustable torque arm on a moser 12. there are 4 bolt holes on the bracket that goes to the TA. they recommend that you use the 'inner' bolt holes, or else you risk the TA rubbing against stuff.
to use the inner bolt holes, you have to cut off some of the bracket.
