moser 9'' and 4l80e driveshaft?
Old 02-28-2009, 01:16 PM
RamAir02TA77's Avatar
Default moser 9'' and 4l80e driveshaft?
Ordered a stock length driveshaft because mine seems to be fine with the 10 bolt and 4l80e but now I did a quick search and found out that the length maybe actaully 1'' short and cause a vibration. Im not sure if the 4l80e is any longer then the 4l60e and maybe it will be fine? My 4l80e has the tailshaft that is the one that is splined most of the way up then the o ring. Im really hoping it will work but my luck it will be 1'' 2 short and vibrate. I wasnt really sure on what to order because the stock driveshaft im using now with the 10 bolt seems to work fine and I just seen that guys with 4l60es were just using a stock driveshaft with a conversion u joint and it seemed to work. Oh well I guess I will have to see what happens.
Old 03-05-2009, 05:18 AM
EPP
EPP's Avatar
The X dimension is what we work off of when measuring for a driveshaft. Bob
Quick Reply: moser 9'' and 4l80e driveshaft?
