Rear end Coil spring removal?
Old 03-09-2009, 09:20 PM
UNmolestedTA's Avatar
Default Rear end Coil spring removal?
How much load is still on the springs if the car is no longer supported by its suspension? I found a car at the junkyard and I want to remove the rear end by cutting the coil springs first and then the tq arm, panhard, and control arms. I feel as though the springs will still have load on them and they may pop out on me. Let me know if this is a stupid idea and btw i am going to use a sawzall. Thanks
Old 03-09-2009, 09:39 PM
jetlag's Avatar
Yes it is a stupid idea..hah
Just get a 22mm socket and unbolt the shock. Jack up the body of the car and the springs will almost fall out.
Old 03-09-2009, 10:41 PM
SS SLP2's Avatar
x 2 simple and safe
Johnny
Old 03-10-2009, 08:55 AM
They junkyard doesn't allow jacks or jackstands but I think I get the point.
Old 03-10-2009, 02:11 PM
jetlag's Avatar
Hah, well I hope you have some strong friends to hold up the car while you remove the torque arm.
Old 03-14-2009, 01:55 PM
Your right, the spring will just fall out! Thanks for the help.
