broken stud
Its easy, I did it a couple of times on my camaro, take off your tire, rotor and the tractions control sensor and you can line the broken stud up with the hole thats left after you remove the sensor and pop it out with a hammer and then out your new one in from the back, and pull it on with a open end nut (not the one your going to leave on the car), and thats it, if i remember right. Hot this helps.
Larry
Larry
