Is there any stronger u-joint options??
blew out the rear u-joint (1310/1350) at the track. Is there any better u-joints or any solutions to this? aside from a cutom DS with the full 1350 joint?
Various mfr make HD joints, Borg Warner, Spicer, etc. Go for a joint WITHOUT a grease fitting for max strength. That grease hole in the joint weakens it.
However, now you have to manually grease the joint every 20k or so (Not a fun job!).
Good luck!
Good luck!
