4 Channel Moser 9" Install
Old 07-18-2009, 01:31 PM
Blown383LS1's Avatar
Default 4 Channel Moser 9" Install
I have a 3 channel rear in my 02 Camaro. I just got a 4 channel Moser 9". I saw in the sticky where the stock 10 bolt can be drilled to accept the abs sensor. On Moser's website it lists the 3 channel rear available with a aluminum center section only. I am guessing it has a boss that is cast into the center section to accept the sensor. Is there anyone that has installed a Moser 4 channel in place of a 3 channel? I don't care if the abs works on the rear I just don't want the abs light to stay on all the time.
Old 07-18-2009, 10:18 PM
taws6m6's Avatar
put it on, bolt it up, get slicks, leave at 6k, shut up and hang on lol. I think you either have abs or you dont, I dont think you can have it on the front or back only. If the light does stay on you can get it tuned out. I appreciate you binging by the injectors man. Well, on the bright side if you lose the abs, just get the abs delete kit with a line lock.
Old 07-19-2009, 01:10 AM
jetlag's Avatar
Blown383, it would be easier to just not mess with the ABS since you didn't get the rear set up for it.
The ABS light can not be tuned out with HPTuners/EFILive. That is on the BCM. Buy some electrical tape and cover the bulb.
Old 07-19-2009, 01:11 PM
taws6m6's Avatar
even better
Old 08-01-2009, 09:23 PM
SHovV's Avatar
remove the bulb = even better
