Wear Pattern
The pinion is too deep in the housing, probably needs to come out .002-.005 but you know what that means. If not you will bust the pinion on a good launch guaranteed or it will at least be a very short time before you buy another when it breaks. Your putting all the forces to move the car on the very tip of the pinion gears teeth instead of the meaty center of the gear. I would definitely move it.
That's what I needed to know.
