axle bearing change
Old 09-21-2009, 09:16 AM
SSoofast's Avatar
Default axle bearing change
Got a bad axle bearing so i'm going change them out. I under stand the procedure,but my question is do I pack them with grease or not? I'm thinking they are lubed by the rear end oil and therefore no grease.
Old 09-21-2009, 02:23 PM
SSoofast's Avatar
Come on guys .Nobodys did this.Do i put grease on the bearings or not???
Old 09-21-2009, 07:41 PM
01ssreda4's Avatar
Yes they are lubed with gear oil. Squirt em down and tap them in.
Old 09-23-2009, 01:46 AM
ultraz's Avatar
yup, lubed through gear oil... Did an axle swap a few months back. I thought the same thing but my brother taught me that only older vehicles need to be packed with grease, newer vehicles are fine.
Old 10-26-2009, 11:29 PM
slow3hoe2's Avatar
Im about to do this. Any tips or a writeup you can link me to?
Thanks much!
Old 10-27-2009, 03:58 PM
cambirdracing's Avatar
Put some gear lube on them before you install them so they don't run dry on initial warm up. When you fill the rear, let it sit for about 15 minutes so the axle tubes get some lube in them and then recheck the level.
