Parts needed to swap from LS1 rear calipers to LT1 calipers?
I'm doing this so that I can get my ProStars to fit without grinding. I have purchased the LT1 backing plates but was curious, I guess I'll need knew bolts, can the e-brake cable just hook into the LT1 setup? I know that the LT1 uses a different style ebrake...
Thanks,
Troy
Thanks,
Troy
1 Post
backing plate. . .
diff gasket. . .
seals. . .
several quarts of gear lube. . .
this is for the disassembly of your rearend since you have to switch the backing plates.
diff gasket. . .
seals. . .
