depends on your axle set up....worst case senario you would have to have a machine shop assemble your axles and press the new studs in. Any reason for a 5/8th stud?
The axles I have now are 33 spline Moser with stock studs. Just want to go with the 5/8" studs because I never want to replace them again and a friend of mine has an extra set I can have so I figured id install and be done with it.
I ment, if you have relucter rings on for abs. And Free studs FTW
