Help diagnois gear noise
rebuilt the rear in a buddys 99 t/a with an auburn pro, motive 4.10s, moser axles, all new bearings, and a solid pinion spacer. had a good pattern and 0.0075" backlash on the setup. he cruised it around town for a few days to break it in and they were quiet as can be, after about 150 miles they suddenly got some serious whine at a steady cruise. we tore it back down today and checked the backlash which is now 0.0085". everything looks fine, nothing came loose. anybody got an idea why they would suddenly get loud?
Yep, I would say its gear noise..... Just messing with ya, Did you recheck pinion preload before you pulled it apart. Maybe the crush sleeve loosened up. Some gears are just noisy. My Motive 3.73s did the exact same thing.
its got a solid pinion spacer. the pinion preload did loosen up some but i'm pretty sure its just the new bearings seating in. whats really bugging me was that they were dead silent for a week and over 100 miles. he drove the car to work, and when he left going home they were making noise
You set the pinion backlash....what was the preload on the pinion bearing? Did yo put the correct spacers in the pinion to get the desired pinion preload on the solid sleeve? Should be about 12 to 18 inch pounds.
