problem after installing gears...weird noise
Old 11-19-2009, 11:01 PM
pboxfun's Avatar
Exclamation problem after installing gears...weird noise
I just finished installing 3.90 gears in to my 94 A4 10bolt. The problem i am having is that when i left off the gas and turn the steering wheel towards the right while making a turn, the rear end makes a weird grinding noise. And the farther towards the right i turn the louder the noise gets. It sounds like the posi unit but I'm not sure. And this only happens when making right turns while the car is decelerating. Does anyone know whats happening or how to fix it?? Any help or comments would be great!!
Thanks
Old 11-20-2009, 09:08 AM
FASTEDDIE Z's Avatar
did you use GM limited slip additive when you did them ?
Old 11-20-2009, 09:49 AM
pboxfun's Avatar
Yes, i did use GM limited slip additive when i put them in.
Old 11-20-2009, 09:40 PM
pboxfun's Avatar
does anyone have any ideas???
Old 11-21-2009, 03:14 PM
It could be your posi unit .Maybe you bent 1 of your backing plates or the E- brake is screwed up .I wish I could be more helpful .but is hard to diag without being there . Good Luck !!
Old 11-22-2009, 06:37 PM
pboxfun's Avatar
im about to go check thos things. Its just a very weird oscillating/howling noise!!!
