really loud whinne
Old 11-27-2009, 03:57 AM
therobman's Avatar
Default really loud whinne
i have a really bad whine during decel in my 10 bolt i mean so loud with my radio up all the way you can still hear it when i let off the gas. i baught a bearing kit because i figured it was it but some one told me you can wear a pattern in the teeth causing the edges to get sharp and then causes the whine is that common? it doesnt clunk or bang it just whines and only when im coasting or off the gas
Old 11-27-2009, 07:42 AM
01ssreda4's Avatar
Time for a freshening thats for sure. If money permits, I would throw new gears in it.
Old 11-27-2009, 04:06 PM
Spartan7's Avatar
The whine you are hearing is most likely a bearing going out, probably a pinion bearing. If you reuse the gears, there is a chance they will whine slightly, since you are changing the contact pattern on the teeth. If setup properly, they should still be relatively quiet.
Old 11-27-2009, 04:33 PM
therobman's Avatar
im going to try to reuse the gears my father who is a mechanic is going to install the bearings just trying to figure out of the gears are toast or not before i drive to his shop its like an hour and a half away im prob just going to pull the cover and see, anything i should be looking for if the gears are the problem
Old 11-27-2009, 08:52 PM
therobman's Avatar
Old 11-28-2009, 01:47 PM
therobman's Avatar
anyone else have any insite
