4:10 A4 DR tire will they break
Old 02-10-2010, 06:51 PM
94-z's Avatar
Default 4:10 A4 DR tire will they break
i just put 4:10 gear in the ten bolt with a baby 2000 stall. I have BFG drag radials on it and its was tuned by PCMforless. Should i be worried about breaking teeth or the ten bolt. Also i am worried about running into overdrive in 1/4 mile. any info guys similar setups?
Old 02-10-2010, 07:33 PM
FirstYrLS1Z's Avatar
with my 4.56s',I go into 4th(what your calling overdrive) in the traps,so with 4.10s you shouldn't be hitting 4th in the 1/4.
a 2000 stall isn't much more than the OEM 1600 stall,my 2600 stall with MT 2.75/40/17 or Nitto 315/35/17 never caused me to be concerned during dragstrip runs about anything in the rearend.Automatics are easy on rearends.
Old 02-10-2010, 07:47 PM
97Z28SS's Avatar
Since your car is an auto you should be ok unless you're running a trans brake.
Old 02-10-2010, 08:35 PM
94-z's Avatar
Nope no trans brake ...... Yet lol thanks guys
