installed my 12 bolt
I put my moser 12 bolt in last night. It was kind of a PITA. My question is I couldn't hook up my sway bar since the moser tubes are obviously larger than on the 10 bolt. Where can I get an install kit that will hook up my sway bar correctly?
Here is a quick way to do it. You can use 3 inch exhaust clamps, you only use the U part of them. Reuse the bottom part of your oem sway bar brackets, you have to oblong the holes out a little towards the outside. Bob
