blew rear end need help on new one
wat up guys i have a 00' T/A without traction control and i just bought a other 10 bolt with traction control i didnt realize that my pick up gear was in my pumkin on my old one. now i was wondering if theres any way to wire the one with traction control so that i have a speedo
Rear diff. sensor
That sensor in the rear differential is for the ABS/Traction control, not your speedo. The speedo is driven off of the pulses from the output shaft sensor on your trans.
Maybe you could wire in the wheel sensors into the differential sensor harness to compensate ?
