Average Shop charge install complete Axle Assembly
Old 03-30-2010, 08:14 PM
texas99Z28's Avatar
Default Average Shop charge install complete Axle Assembly
How much on average, does a typical shop charge for an install of a Strange 12 Bolt for example? To buy one seems to be around $2400.00. Do they come to the shop complete, ready to bolt in? Including Ring and Pinion, axle bearings already pressed on axles, etc.?
Old 04-01-2010, 06:36 PM
texas99Z28's Avatar
bumpp
Old 04-03-2010, 06:05 PM
TurdsOfMayhem's Avatar
any1 able to help him?
Old 04-04-2010, 11:30 AM
00ssmg's Avatar
strang 12 bolts come completely assembled. you would just be changing the whole unit. i would assume a shop is going to charge you a couple hundred. you should do this your self it isnt hard.
Old 04-06-2010, 12:21 PM
conde'strans's Avatar
It comes completely assembled only if you send them the brake plates from your stock 10 bolt or if you tell them to install their own which costs like an extra $300 if i remember correctly! If not i guess they can send it to u without them n then u would have to pull the axles n press everything that goes on the axle yourself.
