Rear Wheel Bearing Replacement HELP!
We just took off the diff cover and after reading GM SPO and my Haynes manual and a buncha text-writeups (no pics) we don't know what we're doing wrong here.
We unbolted a nut inside the diff that's long -- long enough where we can't even pull the whole thing out cuz it gets blocked. In any case, we pulled something out that's being held by that nut and out came this cartridge looking thing. It's black and about 1-2 inches wide, 4 inches tall, and maybe about .75 inches thick. We're trying to get these C-clips out, at least we think they're C-Clips, but they're so buried in there, we're using magnets, flat heads, finger nails, nothing seems to be able to get these out. ANyone know of a picture writeup I can look at or know what we're doing wrong?
This is a 2001 SS Camaro with stock diff.
I was frantically looking for one on here and Google since I was doing the replacement (and stuck) while posting. Everything I've seen/read went directly from "Remove the pin" to "remove the C Clips". My problem was I couldn't get the C Clips out -- because the axles couldn't be pushed in far enough...because the ABS sensor was in the way. I'm surprised that ABS sensor didn't make its way into any of the writeups (including GM Service Manual or Haynes)
