lt1 rear end question
Old 05-05-2010, 10:27 PM
speedracer2536's Avatar
Default lt1 rear end question
ok i searched and read around and couldnt find a straight answer..
i have a 2.73 rearend from a 97 z28 automatic..
my car is a 94 z28 with a six speed.. no abs. no traction control.
i am going to install the rearend from the 97 into my 94
can i install 3.73's for 4.10's onto the carrier in the 97 rear end
Old 05-05-2010, 10:36 PM
bigj2717's Avatar
Yes you can you just need to get gears for a 2 series carrier
Old 05-05-2010, 11:08 PM
so gears from a 3 series wont work? what is the difference? can it be modified to work?
Old 05-05-2010, 11:23 PM
bigj2717's Avatar
Yes you can you just need a spacer. Here is the sticky it tells you everything you need to know https://ls1tech.com/forums/gears-axl...-3-series.html
Old 05-05-2010, 11:25 PM
Jawsgear's Avatar
Yes we have the spacer kits available even though it is not our primary choice due to the fact it moves the ring gear pilot surface up and allows three rotating components to move around which can cause issues if you have a lot of power.
Jeff
Old 05-06-2010, 11:27 AM
http://www.jawsgear.com/Parts_And_Ac...duct_info.html
is this the kit?
