ABS light(how can i get rid of it)
Old 06-05-2010, 09:48 PM
redtail2426's Avatar
Default ABS light(how can i get rid of it)
I installed a 9" rear and a ABS delete kit from sjm,whats the easiest way to get rid of the abs inop light which i am expecting to come on.I knoiw i can pull the bulb or tape over it,but isnt there a way to just groung a waire or connect some wires or something.
Old 06-05-2010, 10:35 PM
eseibel67's Avatar
There is a splice pack near the DLC, should be easy to get at.
The wires colors are gray, dark green, light blue, dark blue, and purple.
The gray one grounds the ABS light to turn it on. Remove that wire and the light won't go on.
Old 06-06-2010, 04:28 PM
well i ended up pulling the bulb,i tried what u said and all it did was make my gas gauge not work
Old 06-07-2010, 08:44 PM
Troy's Avatar
how long did it take to pull the bulb??
Old 06-08-2010, 05:42 AM
it was actually a lot easier then i thought,about 5 minutes,its just 4 screws and the whole gauge pod pulls strait out with circuit board and everything.
Old 06-08-2010, 07:22 PM
TooFast3800's Avatar
Where are these 4 screws? I can go look but just so I know. I need to do this to my car. Did you pull the BRAKE light and the ABS INOP bulbs or just the ABS INOP? Both of mine come on when I drive because no ABS etc. Might do a gauge overlay and some LED dash lights while I'm in there.
Old 06-08-2010, 08:37 PM
welman transam's Avatar
i have abs inop sevice vehicle and brake light on mine just from one 3 channel abs sensor! I couldnt believe it.
Quick Reply: ABS light(how can i get rid of it)
