Richmond 4.10s go boom - 10 bolt carnage
Old 06-13-2010, 04:36 PM
ThumperNC24's Avatar
Default Richmond 4.10s go boom - 10 bolt carnage
I don't know if you saw my last thread or not - but yeah 10 bolt is broke.
Pulled the cover - two teeth sheared right off the ring gear. Fluid looks really good - lots of backlash from the wheels though. I think the only thing that is broken in the gear. The car has a mechanical torsen differential and that seems to be ok.
Next step is to pull the whole rear out of the car - also need to order new ring and pinion as well as a rebuild kit. Think I am going to go with new GM Gears - still in 4.10
Pics:
Old 06-13-2010, 08:11 PM
MYSTIC-1SC's Avatar
damn gotta hate when that happens.
Old 06-13-2010, 09:00 PM
KCC455's Avatar
Default Also broke 4.10 ring gear teeth
Mine did the same thing about a week ago except I broke 4 teeth off the 4.10 ring gear. I am going to try 3.73 GM gears and save up for a MWC 9".
Good Luck with yours
Old 06-13-2010, 09:04 PM
redwing1's Avatar
I am thinkin about getting some 4.10 gears where the richmonds noisy or quiet?
Old 06-13-2010, 10:29 PM
mine were really noisy - I am switching to GM because I have heard they are the quietest.
I thought about going with a different ratio but I have a feeling I will just be disappointed with the performance. I am just going to avoid the track until I can afford a MWC 9" for it after I graduate. Hopefully next winter.
Old 06-13-2010, 10:34 PM
LaBLKv6Z's Avatar
What kinda rubber are you running in the rear?
ULTIMATEORANGESS's Avatar
ive gone through a couple gear sets. motives tend to be quiet when setup properly. good luck.
Old 06-13-2010, 10:38 PM
245/40/ZR18 Dunlap Direzza Z1 Star Specs - they are sticky for a street tire but they are still a pure street tire. These are not as sticky as a drag radial (even nitto) but they are 200 treadwear. I thought it could survive that but I guess not. Best 60' I cut was 2.17 with wheel hop.
Need to add relocation brackets
any experience with GM gears?
Old 06-13-2010, 10:43 PM
redwing1's Avatar
I have a buddy that told me a gear made by a company called yukon is pretty strong and quiet as well anyone heard of these ran a set?
Old 06-13-2010, 10:50 PM
LaBLKv6Z's Avatar
Yeah those are pretty sticky for street tires. I was running nitto DR's and had scary wheel hop on the streets. Currently running Richmond 4.10's so I swapped to some harder compound kumhos. Good luck with the next setup man, I'm still dreading the day my rear lets go lol.
Old 06-14-2010, 01:02 AM
Soul TKR's Avatar
you and me both! Wish I could one day get a MWC 9".... student loans suck
Old 06-14-2010, 01:13 AM
LS1_Sean's Avatar
thats a bummer. Im running the same gear set, mine are actually pretty quiet.
hopefully mine last till i can get a 9in.
Old 06-14-2010, 01:26 AM
meine96ws6's Avatar
Well, that combo alone isn't good.. your going to break something if your wheel hopping that hard.. there is a ton of tension as your launching
Old 06-14-2010, 09:03 PM
it wasn't hopping that bad - it was there but not like insane. that is what everyone at the track said anyway.
Old 07-28-2010, 04:50 PM
ryans01z28's Avatar
i was having problems getting the paddel put in when installing 410s in mine and i called a guy and told him about it an the horsepower im running and he said get rid of that torsen carrier if running 410s or youll blow up the rear end the 1st time u step on it JUST LIKE YOURS lol. glad i didnt get that block in. he said he ran the torsen and blew rear ends all the time and now has auburn and no probs. im looking for an auburn right now. good luck
Old 07-29-2010, 12:50 PM
Jawsgear's Avatar
They are made in India.
GM Gears are by far the best to go with to avoid any kind of gear noise as long as they are set up properly.
Wheel hop of any kind is not good on any differential and can cause damage.
Jeff
Old 07-29-2010, 09:49 PM
02 BLK WS6's Avatar
4.10's in a 10 bolt will never last behind decent power. I went through 2 sets in one season cutting 1.5x 60'. The ring gear teeth are too thin.
Quick Reply: Richmond 4.10s go boom - 10 bolt carnage
