Couple Questions about changing the rear diff fluid
Old 07-07-2010, 01:05 PM
MTBSully's Avatar
Default Couple Questions about changing the rear diff fluid
I want to change the diff fluid in my 2000 SS. Is there any way to tell what kind of posi i have (torsen or auburn) without taking the cover off? Also, how do you drain the old fluid, and how much new fluid does it take? Thanks
Old 07-07-2010, 01:22 PM
Jawsgear's Avatar
Jack up both rear wheels, car in neutral, spin one tire. If they go oposite directions you have a torsen, same direction you have an aubirn. In order to drain the fluid you have to pull the cover. It will take 2 quarts and an addiitve if you have a Auburn. No additive necessary for a Torsen.
Jeff
Old 07-07-2010, 02:10 PM
MTBSully's Avatar
^^^good info thanks. Hopefully the local autozone has the gasket for the cover in stock.
Old 07-07-2010, 02:38 PM
killagt's Avatar
no gasket ! just use black rtv
Old 07-07-2010, 04:39 PM
98RedRocket's Avatar
This is on my list of things to do in the next couple weeks.....good info thanks!
