Is this the right housing end & 9'' Install Questions
Old 07-22-2010, 06:02 PM
69RS's Avatar
Question Is this the right housing end & 9'' Install Questions
http://www.moserengineering.com/othe...lip-axles.html
I'm narrowing a 9'' rear for a 2002 Firebird. Is this the end i need to be able to use with the factory disc brakes ? Any tips on swapping all the brackets over would be appreciated.I have the Currie torque arm bracket ordered.I have narrowed rears before but not this type.The car has Wolf mini tubs in it allready, from what i have read the way to go is 3'' off each side and run a 15x10 wheel with 5'' backspace and this should clear a 29x10.50x15 slick. Correct me if i'm wrong, Thanks
Old 08-16-2010, 12:35 PM
Gimme's Avatar
I'm not sure about your install questions, but in order to run the factory disk brakes, you'll need the 7900FM (Flush Mount) ends and the Moser T-Bolts. Don't forget to order the correct bearings for the 7900FM ends, as well.
Hope that helps,
Jon
