Dana s60 rearend fitment ??????
Looking to purcahse the following but had some concerns: Strange S60 Its in great shape no problems at all. It has a Detroit Trutrac, 35 spline axles, and 4:10 gears....So will my stock LT1 brakes hook up on this rearend, wasn't for sure if it was going to be compatiable or not. It's a channel 3 and it is out of a 2000 SS Camaro. Any info would be great on this install, thanks
93-97 and 98-02 use different style rear brakes and mounting plates. You could convert your car to work with the later style brakes, or you could dissassemble the rear end and install the early style brake backing plates and use your existing brakes.
