abs question
If you get the SJM kit it eleminates the abs block and gives you new lines to run from the master cylinder to 2 T blocks that you hook up to your stock lines. It also has a proportioning valve to control brake bias and dial in your brakes. Its a good time to get a line lock if you dont have one and need one
