gears/rear end
gears/rear end
i have a automatic 2000 trans am. i want to go with 3:73. what all would i need to switch over. i also have a question about 12 bolt rear ends. what would i have to do to make it a 12 bolt. i dont know anything about rear ends so any info you guys could give me would help alot. thanks
Internet Mechanic
To break to down, simply. You are asking 2 entirely different questions.
Feel free to ready the stickies up top as they provide a wealth of information.
Moving forward, to change your gearing in the stock 10 bolt rear. You need to either contact a performance shop and they can guide you, or get someone local who is good at rear gear swaps and buy the parts.
Question: Does your automatic has a selection for 1st gear?? Or after "D" can you do down one click more. As if I recall the cars with 2.73's had a different carrier then those with 3.23's and that would matter when doing a gear swap in a 10 bolt. I myself never bothered as they are weak rears and I moved on to swapping in a 12 bolt.
Now, you cannot convert your 10 bolt into a 12 bolt, its a major investment that is over 2500$ to do so if you dont have the scratch, then do not worry. Focus on buying a install kit, gear set, oil, differential additive (GM only), and give the parts to a qualified mechanic and have the PCM reporgrammed.
Internet Mechanic
http://www.thunderracing.com/shop-by...-Install-Kits/
Notice where they say 2 series and 3 Series. You have the 3 Series.
Have fun!
Also!
http://www.thunderracing.com/shop-by...and-Additives/ You can and should use NON synthetic rear gear lube but if you have a Posi you need this at the bottom of the screen.
LS1Tech Sponsor
https://www.brutespeed.com/rear_end_information.htm
I have a lot of information at the above link that might help you out. Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
