12bolt Moser Axel seal?
One of my seals is leaking on my moser 12 bolt,does anyone no what the part # I need for the axle seal.I have a slide hammer to get the old seal out.How do i put the new one in?
Internet Mechanic
Dave, you basically need to pull out the old one, then use something that is close to the inside diameter of the axel tube to even get the seal in place. Also what I learned is you should pack the inside with some axle grease, it keeps the spring in place which can get dislodge on the install. That keeps the tension on the inner seal.
Also clean the tube out and then put some engine oil to ease the seal on the install.
