rear help
Old 09-22-2010, 03:53 PM
1Bad97WS-6's Avatar
Default rear help
I just got my 373 ring and pinion package and the Bearings and seals package has 82-98 Iam wondering if any body nows if the bearings and seals are the same in my 02 rear end or are they differant..Thanks Jimmy
Old 09-22-2010, 04:23 PM
FirstYrLS1Z's Avatar
SAME except for potentially pinion seal,2 varieties towards end of production 00-02.
Old 09-22-2010, 04:33 PM
1Bad97WS-6's Avatar
Thanks for the quick reply So should I send it back to jegs or just keep it and get a new pinion seal at napa or some where.
Old 09-22-2010, 05:08 PM
you won't know which you need until you pull the seal out,so you could have the correct seal,if not,take the removed seal to your local parts store and get a match.
do a search in this 'gears and axle' forum for 'pinion seal' to get familiar with the potential seal mismatch.
Old 09-22-2010, 06:18 PM
1Bad97WS-6's Avatar
Thanks just keep it and get a pinion seal if the one I have is wrong.A pinion seal couldn't be that much..So Bearing and everything is the same but the pinion seal..
